Säästätkö energiaa?
- ihmehitsari
Säästätkö energiaa?
Aikojen ollessa mitä ovat, on ajan yhtenä teemana energian säästäminen ja jopa oman päätöksenteon ulkopuolelta johdettu säännöstely.
Jotenka, mitä toimenpiteitä on tehty tai tulet tekemään energian säästämisen suhteen?
Omassa elossa ei vielä isosti ole kohteita valikoitunut. Hakusessa on nuukaan eläjän kohteet. Tosin eilen makkaraa nuotiolla grillatessa hajotin nuotion kyrsien kypsyttyä, eli siirtelin puupökäleet erilleen hiipumaan ja nähdäkseni tällä toimenpiteellä sain 1/3 nuotiopuista säästettyä seuraavaan kertaan.
Saksassa, Hannoverin kaupungissa saa enää kylmiä suihkuja julkisissa paikoissa. Sitä ei uimahallin suíhkussa lutarata.
Cold showers as German city of Hanover reacts to Russian gas crisis
The German city of Hanover has turned off the heating and switched to cold showers in all public buildings because of the Russian gas crisis.
It's the first big city to turn off the hot water after Russia dramatically reduced Germany's gas supply.
Germans have been told to expect sweeping gas reduction measures and extra charges on their energy bills.
And the EU has agreed to lower demand for Russian gas this winter by 15%.
In a bid to save energy, Germany's northern city of Hanover has decided hot water will no longer be available for hand washing in public buildings, or in showers at swimming pools, sports halls and gyms.
Public fountains are also being switched off to save energy, and there will be no night-time lights on major buildings such as the town hall and museums.
Mayor Belit Onay said the goal was to reduce the city's energy consumption by 15% in reaction to an "imminent gas shortage" which posed a significant challenge for big cities.
The rules apply to heating, too. Public buildings will not have any heating from April to the end of September each year, with room temperatures limited to a maximum of 20C for the rest of the year - with some exemptions.
The city is also banning portable air conditioners, heaters and radiators.
https://www.bbc.com/news/world-europe-62335911
Re: Säästätkö energiaa?
Noin kerta viikkoon elämänluukulla käytävä, siitä ei voi juuri tinkiä. Sähköä ja pellettiä kuluu tasaisesti, ei oikkee siitäkään. Klapeilla sauna, ei siitäkään.
Kerta-pari viikossa on karstattava itseään. Sensuaalipuuhat ovat kovasti energiaa kuluttavia mutta sekin alkaa olla jo niin vähäistä ettei vaikutusta. Ei tässä oikein tiedä, mistä säästäisi.
Talon ikkunat on tosin tarkoitus tiivistää. On jo 150 metriä hankittu p-profiilia ko tarkoitukseen . Yläpohjaan puhallusvillaa, siinäpä ne.
Talon keskulämmityskattila toimii puulla kuten tähänkin asti. Noin kahden vuoden puut tehtynä. Käyttövesi lämpiää samasta ja sarjassa sähkövaraaja. Saatetaan nostaa puulämpöä ja vähentää sähkölämpöä käyttöveden lämmityksessä. Kesäaikaan pidetty 40C säädöllä ja sähköllä niin ei tarvitse puita polttaa.
Talon valaistus on vaiheittain siirtynyt jo ennen ryssien hyökkimistä LED-tekniikkaan poislukien alakerran tekniset tilat joissa valaistus päällä vain kuljettaessa. Siellä on loisteputket. Vuosi sitten autotallin loisteputkivalaisimiin vaihdettu LED-putket.
Viiden vuoden sähkönkulutksen keskiarvo noin 5700kWh/a. Asialle ei ole aikomus tehdä mitään. Huhtikuussa asennettu aurinkopaneelit, tuottoa tulee aurinkoisina päivinä kulutuksen verran. Aikomus asentaa n. reilu 3kWp lisää. Tällöin korkean pörssihinnan aikoihin saa myyntituloa puolen vuoden ajalta.
Pakettiauton vaihtohetken siirtäminen tulevaisuuteen. Palkkatyöpaikalle pyöräily sähköpyörällä. 15 vuoteen autolla ei ole turhaa ajoa harjoitettua eikä myöskään minkäänlaista matkailua joten säästöpotentiaalia 0%
Keittiöön haaveiltua kaasuliettä ei hankita. Ryssän verikaasulla meillä ei kokata.
Yläpohjan lisäeristys ollut suunnitteilla ja hankittu tarvikkeita. Energian hintarakenteen vuoksi meillä sillä ei saavuteta erityistä rahallista säästöä. Tarkempi ajankohta varmistuu kun seurataan laskeeko materiaalien hinnat ja millaisen tarjouksen puhallukselle saa. Ylipäätään remontteja ei tänä vuonna isommin tehdä ajan puutteen ja materiaalien hinnanousun vuoksi. Säiden kylmettyä vinttiprojektia kuitenkin tarkoitus valmistella.
Sivuajatuksena jonkinlaisen dieselaggrekaatin hankinta/rakentaminen. Kohtalaisen toimivaa laitetta voisi myös ajatella vuokrattavaksi. Polttoöljyllä sähkön teko maksaa noin 60snt/kWh eikä mukana ole huoltokuluja.
Aika pieniä tekoja tullut tehtyä. Pyykinpesun siirsin taloyhtiön koneelle, siitä kun ei tarvitse maksaa. Kahvikeittimen sammutan melkein samantien, kun kahvi on valmista. Vedenkeittimessä kiehautan vain tarvittavan vesimäärän. Autoilua olen vähentänyt, ehkä 10%.
oppia ikä kaikki
Klapikone on vaihtunut, tosin jo pari vuotta sitten sähkökäyttöiseksi.
Ja rouvan bensavolvo on juuri vaihtumassa tuoreempaan pikkukoneiseen dieseliin. Ajaa ihan älyttömät määrät työmatkaa vuodessa.
Tänä kesänä ei ole venematkoihin mennyt vielä tippaakaan bensaa, kun on sähköperämoottorilla ajettu yhteysvenettä. Akku ladataan saaressa aurinkosähköllä. Joka päivä ei paista aurinko, joten säästellen pitää toimia. No, on siinä airot backuppina, mutta vielä ei ole tarvinnut varavoimaa käyttää.
Isompi paku vaihdettiin viime kesänä uudempaan pikkupakuun ja ylläpitokulut putosi siinä jo 800 euroa vuodessa. Omat ajot mennään ladattavalla hybridillä ja sähköä kuuluu se mikä on välttämätöintä. Taloon laitetaan tässä syksyn päälle mahdollisuus syöttää virtaa diesel aggregaatilla ja jos ensi vuonna raaskisi laittaa aurinkokennopaneelit katolle.
1995 JCB Robot 150
En säästä mitään sen kummemmin kuin ennenkään. Enkä tuhlaa sen kummemmin.
Elämä soljuu urillaan samaan malliin maailman menoa ihmetellessä.
En erityisesti säästä muttei tuhlatakkaan.
Kylvömuokkaus karhituksissa on siirrytty jo muutama vuosi sitten pääosin yhteen ajokertaan. Siinä säästyy jonkun verran.
Toiseen kuivaamoon hankittiin AirHot esilämmittimeksi pitäisi vähentää polttoöljyn kulutusta... Saatetaan sillä halliakin lämmittää, mitä ennen on masterilla lämmitetty tarpeen mukaan.
Vähän vaikialta tuntuu säästäminen. Vanhin likoosta muutti 90 km kauemmas ja tuntuu että harva se viikko tuloo asiaa sinneppäin, onneksi nuorimmaanen on siinä puolivälis jottei sen takia jouru eri suuntahan menemähän.
Työmatkoja ei onneksi tarvitte autolla ajella kun työt hoitellahsn kotua päin.
Ehkä energiaa säästyy vähän kun kaikkea ei enää meinata kyntää ja emännyyrelle tuloo uus läppäri joka vie torennäköösesti vähemmän virtaa
Tässä talossa on kulunut noin 10 000 kWh sähköä vuosittain ilman mitään tinkimisiä lämmöstä tai lämpimästä vedestä. Viisihenkinen perhe ja reilu 200 m2 lämmintä tilaa. Maalämpöpumppu vie vajaan puolet tuosta. Paha alkaa vähentämään.
Tänään hajotin makkaranuotion puut ja jatkan niillä huomenna.
Autoilu vähentynyt reilusti etätyön myötä, mutta vaimo rullaa kovasti. Ei oo vielä keksinyt munamankelin säästöpotentiaalia.
Ajelua oon vähentäny. Vien auton säädettäväksi, saa liikaa bensaa. Kertaakaan ei oo sähkösauna lämmenny tänä kesänä. Ei kyllä puulämmitteinenkään ku kerran, kun lämmittää hyvin myös koko tönön samalla. Syssymmällä. En oo ostanu uusia vaatteita. Pengon omaa kaappia ja hämmästyneenä löydän sieltä ihan uusia riepuja. Ostan ruokia rekosta. Kahen viikon satsi kerralla. Ei tarvi ajella markettiin. Normisti kuten aiemminkin, täysiä koneellisia pyykkiä / astioita. Nyt myös täysi kieroilmauunillinen ruokaa kerralla. Pieniä juttuja
www.sohvinkulma.fi
Autolla nopeuksia vähentämällä olen saanut litran satasella pienenemään kulutusta. Kotiin uusittiin boileri pienempään ja mökille uusin boilerit vähemmän energiaa tuhlaaviin. Mökille myös saunaremontin yhteydessä tarkoitus laittaa lämminvesikerääjä katolle, jolla saisi ainakin aurinkoisina päivinä säästöä. Mietin myös samalla perustuksen alle sijoittaa "maalämpöputkiston", joka kylminä aikoina voisi olla hyödyksi. Valaistukset on kaikkialla vaihdettu ledeihin jo vuosien varrella.
autoilua on tullut vähennettyä niin paljon kuin mahdollista, korkean polttoaineen hinnan takia.
sähkösopimus on vielä edullinen reilun vuoden ajan, niin sitä ei erityisemmin ole tullut säästettyä, hieman yrittää säästää siinä kuitenkin esim. laskemalla märkätiloissa olevien sähkötoimisten lattialämmityksien lämpötilaa.
Talo, käyttövesi, sauna ja konehalli lämpiää kuitenkin oman metsän klapeilla, niissä säästöpotentiaali on minimaalinen rahallisesti, joten lämpöasteita meillä on sisällä yhtä paljon ensi talvena kuin ennenkin.
mahdollisiin sähkökatkoihin on varauduttu varavoimalla jolla saadaan toimimaan lämmitys ja kylmälaitteet. puukamiinan hellalla ruoan valmistus, vesihuollossa tarvitsisi siinä kohtaa turvautua kantoveteen, mutta elämän edellytykset olisi silti hyvällä tolalla
Viimeksi muokannut klapikalle, La Heinä 30, 2022 2:03 am. Yhteensä muokattu 4 kertaa.
No bensaa varmaan on hieman säästynyt, kun osa venereissuista ajettu putput paatilla dieselillä. Eipä juuri muuta, kun ei hirveesti tuhlaakaan. Puuta on lomalla palanut normaalia enemmän, kun lähes joka päivä saunassa.
Vähän kiusallinen aihe.
Jos elämänmuotomme säilyy entisenlaisena, aika vähän pystyy säästämään "lite bättre" tavoilla. Puu- ja lämpöpumppulämmityksellä mennään kohtuullisilla lämpötiloilla, kaupungin sähkösaunaa ei ole lämmitetty vuosiin, suihkuun ei leiriydytä. Kuljen vaimon perässä, sammutellen valoja . Ledit ovat kynttilöinä. Varsinaista hupiajelua autoilla ei tehdä, joistakin (harvoista) ostosreissuista vain tehdään samalla pienoisia turistikiertueita.
Mutta.
Eihän tämä oman sakin elo kaikkein järkevintä ole, energianuukailun kannalta. Viikot on oltava kaupungissa, sekä vaimo että minä koetetaan tienata elantoa. Hiukan liikaa tilaa siellä, paritalon puolikas. Työmatka on kyllä lyhyt ja hoituu vaikka fillarilla molemmilla. Veri ja aika monenlaiset puuhailut vetävät maalle joka ainoana vapaana hetkenä, ei voi mitään. Siitä tulee ajoa päälle 10 tkm per vuosi, siitä voisi kai niistää, jos hermo kestäis. Autot käyvät dieselillä, ehkä tulevaisuudessa toinen voisi olla sähkösuristin, mutta nyt ei riitä varannot. Vene käy dieselillä ja pikkukanisteri riittää koko kesäksi. Moottoripyöräily on jäänyt nykyään vähiin. Traktori polttaa oman osansa, jollakinlailla hyötyajoa kuitenkin. Aurinkopaneeleihin ei ole ymmärretty investoida, vielä. Kaikenkaikkiaan en ole pysynyt ihan ajanhermolla tekniikassa, liikaakin on tullut odoteltua tyyliin "en halua olla uuden tekniikan koekaniini ja maksaja". Pitääpä vähän päivittää ajattelua .
Mutta.
Eipä tässä paljon säästelemään ole alettu, entisillä mennään. Talossa asustaa neljä henkilöä ja lämmintä tilaa n. 250 m2. Sähköä ostetaan n. 1200 kWh vuodessa, kokonaiskulutus reilu tuplat tuosta. Talon saa pidettyä lämpimänä sähkökatkojenkin aikana. Juomavettä on aina varastossa 20 litran kanisteri, kunhan aika ajoin muistaisi vaihtaa sen. Joesta ja purosta voi hakea veden vessanpöntön käyttöön, talvella tietty avanto tehtävä. Autoihin en ole polttoainetta hamstrannut, tiukan paikan tullen käytetään sitten tonkimakoneen löpöt, jotain reilu 100 litraa. Eläessäni en ole energiaa tuhlannut, jo lapsena minut koulittiin napsauttamaan valot pois huoneesta, jos sinne ei jäänyt kukaan. Samoille tavoille koulinut perheeni.
Vävyntekele (ei enää kuvioissa) oli kummallinen, lotrasi suihkussa pitkälti yli puoli tuntia. Silloisessa talossani oli puilla lämmitettävä varaaja, tilavuudeltaan 80 litraa. Tyttären porukka kun tuli meille saunomaan, kävimme vaimon kanssa ensin saunassa ja sen jälkeen vieraat. Vävy suihkutteli viimeisenä. Annoin tulen sammua varaajasta, niin eihän lämmin vesi pitkään riittänyt. Vävykään ei sitten kymmenasteiseksi jäähtyneellä vedellä kauaa peseskellyt (20 min.), ei rassu tainnut saada puhtaaksi kuin puoli kroppaansa.
Vuk, välillä sitä kaipais lisä-energiaa jotta pääsisi soffalta ylös. Joten pankaa lähettäen säästämänne energiat nimimerkille: " Veltto sekatyömies ", Poste restante.
- ETS
Aika säästeliäästi saa kyllä elellä, jos tuolla kulutuksella vuosi menee, on mennyt aikanaan oppi perille
Meillä 5 henkinen perhe ja kaksi viimeistä vuotta 23000kwh mennyt per vuosi. Tosi laiskasti mitään säästelty ja lämmitys 98% ollut sähköllä. 2 ilmalämpöpumppua löytyy. Ensi talvena pitäisi puunpoltto nostaa 80% ja loppu lämmitys sähköllä. Nyt jos tuon puusaunan saan tehtyä ei mene lämpimään veteen ja saunan lämmitykseen sähköä.
Käyttäjiä lukemassa tätä aluetta: Ei rekisteröityneitä käyttäjiä ja 68 vierailijaa
